hey all. i done a search for a while, but couldent find much.. ive installed my apexi el boost gauge, but have had trouble puting it some were. pillars and what not, i dunno, some say its illegal and some not. but, cops may put you over any how, dont really want that :laugh:..
has any one mounted a gauge of 60mm in a driver vent on a r33?
heres a pic i found of a r32, he seems to have something in the vent for a gauge. does any one know were to get these?, or how to mount beta into a vent. mines ok, but i want it perfect.
Mine is just inside the vent with the apexi stand that comes with it, bent to the side. any other ideas were to mount? r were to get a vent mount? thanx
below on the left is the 32 with vent mounts.. and the 2 pix after are mine and were i need to mount..
Edited by seriesII
https://www.sau.com.au/forums/topic/148329-boost-gauge-in-driver-vent-r33/
The 33 vents are a werid shape to mount any guages.. Unless you buy smaller 52mm or 42mm guages and make a custom mould in there to hold it in..
Otherwise it will end up looking like the pics you posted above!! WHICH looks crap to be honest..
Get yourself a dual a-pillar guage..
Yes i know it could be a defect.. but ohh well.. You didnt buy your car for nothing..
Or another option is to buy a triple guage cluster that fits into your din pocket.. Defis make them.. and im sure justjap make those tripple holders also..
Now another option is to drill holes into your glove box.. and mount them flush in there..
OR you can just mount on them on your dash..
Or dont have any guages at all..
get a power fc which reads most of the readings.. Or get a dual turbo timer which also reads the amount of boost!!
seriesII - i was thinking of that spot myself. quite a good position if you think about it. not as defectable seeing as it is under that threshold of steering wheel height.
i would probably make a custom mount to go there.
WogsRus - awesome specimen of an r33 interior! so clean and smooooooth :rofl:
siddr20: thanx for the tips. yeah, it loox worse in the pix. sorta loox ok there, but doesent look clean at all. i really wanted it in that vent :laugh: . its easy to see when driving, and a boost gauge normaly is were you can see it quick i guess..
ive got a power fc. but i never keep the hand control in there. ppl like to steal :laugh:. and the el gauge is easier to read at night..
i think i might have to go for a defi din pocket.. and it will look a bit beta in that spot i have a cheap holder there..
Logikal: yeah, you cant see it much from out side, its a awesome spot, that vent never blows on me anyhow... were did you put your gauge?
im not really looking to get pulled over. not really wanting cops to look over other stuff, and defeat me for a gauge then it moves onto other bigger fines, that im sure they may fine :P
WogsRus: its ok reading the gauge there?, cause i might do something arund that area now..
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
