I've noticed that my GTR's acceleration in second is no longer smooth. It starts boosting and then suddenly drops for a split second and then again and again all the way to the redline.Does any one know what could be causing this. I did take the boost restrictor out but it was fine for ages before this happeed.
https://www.sau.com.au/forums/topic/148554-jerky-boost-on-gtr/
do you have std coils?
when did you replace the plugs last?
you should try running a spark plug gap of about .8mm should help if it is dud coils
yep sounds like the common old Coil packs cracks. the spark arcs out instead of firing the spark plug ... I would say it it has happend due to the extra boost and heat your generating from removing the restrictor ... Same thing happend to me
I replaced the plugs about 15,000km ago and i'm runnng standard coils
Does regaping plugs solve this problem or is it just banaid solution.
Also, roughly how much are new coils?
You can get new splitfire coils for just over $500 a set delivered
And try changing your plugs aswell as i think copper plugs are only good for 10,000km. I change mine every 5000km when i service the car as they are only an extra $20 or so.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
