AS TOPIC STATES, THIS POWER FC IS IN IMMACULATE CONDITION. ALSO COMES WITH HAND CONTROLLER IN ORIGINAL BOX.. HAS BEEN USED FOR 1 WEEK ONLY.
SALE PRICE IS $950 FIRM INCLUDING DELIVERY TO ANYWHERE IN AUSTRALIA
Edited by GTRGTR
