  • Replies 135
Posted Images
Yeah ! been waiting all year (only go every second year) Should be good this year lots more cars entering apparently. More and more imports etc. every year now. Was thinkging about taking my car in just to drive around but it is super stessfull a mate of mine ended up just gettin his g/f to drive withle he got on the piss just so he would'nt care about people touching the car etc. (old skool ford ute). A bit of a cruze on the friday might be fun !
https://www.sau.com.au/forums/topic/149509-summernats/#findComment-2787822
It's pot luck i guess. I normally take the line but park away in one of the far off car parks for a little bit of peace of mind... If it isnt some bogan who just doesnt like jap crap or some theif who likes the look of a line either way i personally don't feel comfortable at summernats. Braddon is a little different there are so many jap cars out there at times they almost out number the big aussie cars :)
do u think it will be that bad
https://www.sau.com.au/forums/topic/149509-summernats/#findComment-2787999
Do you really think it will be that bad to have a skyline (crazy graphics all over it) in the car park. Being ACT peoples you would probably know best. I haven't taken an import to nats before...
Maybe I'll catch a bus from the room....
Any good places to 'cruise' around ACT for some action....
https://www.sau.com.au/forums/topic/149509-summernats/#findComment-2788646
i probably wouldnt take the car then, summernats isnt exactly rice friendly. ill probably drive the silvia there, only because it doesnt really stand out from the crowd.
Edited by SKYLVIA
https://www.sau.com.au/forums/topic/149509-summernats/#findComment-2788899
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
