im selling my direct port nitrous kit complete with lines bottle everything needed to fit comes with a full bottle of gas and is jetted to 108hp 6 cyl kit can be used on 4 cyl and rotor aswell
price $950plus freight
ring jason on 0424348521
how easy are these kits to install?
https://www.sau.com.au/forums/topic/149538-sold/#findComment-2797970
  • 1 month later...
hi
is this kit sold yet? where are you located?
is it the direct port fittings that sit under each injector or a fogger tapped into the manifold near each cylinder?
thanks
Justin
https://www.sau.com.au/forums/topic/149538-sold/#findComment-2897928
  • 3 weeks later...
kit comes with 10 pound nitrous bottle
braided main nitrous line
nos solenoid
fuel solenoid
6 seperate direct port foggers with jets
braided lines from solenoids to distribution blocks
and solid lines from distribution block to foggers
kit is complete ready to use
freight will be no probs anywhere in aus or tasmania
new price $800 plus freight
https://www.sau.com.au/forums/topic/149538-sold/#findComment-2938400
600rwhp 15 psi no gas
the reason for sale is the nos was to get the turbo onto boost with a 4500 rpm stall converter as street registered car ran 9.3 @141mph
the new engine runs a methanol motor with a 5200 rpm stall converter and 2 step so no need for the gas anymore
nos was also used to win dyno comps which im also not interested in anymore
Edited by jas/slo32
https://www.sau.com.au/forums/topic/149538-sold/#findComment-2950486
Have left message on your phone and sent pm , please call me - thank you :(
https://www.sau.com.au/forums/topic/149538-sold/#findComment-2953560
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
