HOLDEN CALIBRA 1991 YE
- 2.0 ltr FWD
- 5 spd MANUAL
- 200,000kms
- Full electrics, windows, mirrors, boot solenoid
- Heater and AIR CONDITIONING
- Central locking
- Sunroof (requires a service, havent used in ages)
- Pioneer basic head unit, Pioneer fronts and rear 6x9s sounds pretty good.
- Tinted Windows
- Just received a MAJOR 100,000 service as listed below.
As stated above guys, this is what i have for sale. I intended to have it as a 2nd car for less hassles but change of plans as im buying a new car.
The car is near faultless now. I have replaced :
- Distributor/cap
- Spark Plug leads
- Spark plugs
- Full service, all fluids flushed, new oil
- Timing Belts, seals, 100k service
- 4 brand new tyres
- Reco gearbox
The engine bay has been maintained extensively and everything has been done to make it a reliable car. The only problems are the alternator is still good but for 100% reliability, needs a reco. The car plays up when theres 1/4 tank of petrol left, reason mechanic said, the hose in the tank is broken, easy fix.
Other then that it starts first time and runs beautifully, very smooth ride. interior is in excellent condition for its age. Paint outside car is excellent, just tiny dents here and there like any other car. Car WILL pass a RWC.
Asking $4,200. or $5,000 with 1 years rego with RWC! (rather not as i dont have time for it!)
Contact : 0434-382-736.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
