Bore x Stroke: 83.0 x 73.7
Displacement: 2393cc
Compression: pre '83 8.5:1 & post 8.9:1
Max Power: 93.4Kw @ 5600
Max Torque: 179Nm @ 4400
Tank: 65L
Gear ratios: 1st 3.321:1, 2nd 1.902:1, 3rd 1.308:1, 4th 1.000:1, 5th 0.833:1 Rev 2.400:1
Final Drive 3.900:1
Length: 4620mm
Width: 1675mm
Height: 1390mm
Wheelbase: 2615mm
Track: 1410F & 1395/1400R
Ground Clearance: 160mm
Turning Circle: 11.2M
Kerb Weight: 1215/1250kg
Anything else?????
Cheers, D
https://www.sau.com.au/forums/topic/149678-l24-e-help/#findComment-2791247
sorry it took me awhile to reply i had to nip down to the gold coast yesterday... heres a pick of the car from the fron that shows the width and i also included a pick of the compliance plate incase u where interested
That's ok, it's just that I wasn't exactly shore when the S2 change came in 83.
As yours is an S2, made for the 84/85 market you can be sure you have 8.9:1 compression.
You want to send me a PM with some numbers for you, coz I'm going to be in Qld later this month.
Cheers, D
https://www.sau.com.au/forums/topic/149678-l24-e-help/#findComment-2795737
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
