so its not at any particular rpm, but more so when the engine is under load?
I think it could be:
Could be the air volumes being measured by the ecu are wrong, this being caused by a boost leak or a fault in an electrical component (AFM, AAC, O2). either way, the air thats getting pumped thru the engine isnt matching what the ecu is reading. I dont think it would be a dirty pod filter or a collapsing pipe between the AFM and turbo because you're making full boost.
OR
Fuel system problem. when the engine demands alot more fuel when on increased boost from cruising or idle, the fuel pump might be bad and not be keeping up, or the lines/filters might be partially blocked only allowing enough fuel thru for idle and cruise mode....
So I'd check: AFM, O2 sensor, AAC valve - these bits you may have cleaned but could they just be broken? Fuel pump, all fuel lines, fuel filters, fuel injectors. All air lines and hose clamps, fuel pressure reg. to plenum line in particular. Alot of this shit you've done so on goes the process of elimination! :thumbsup:
hope i could help :D
cheers
rb25
https://www.sau.com.au/forums/topic/14988-slow-r33/page/2/#findComment-480213
  • Replies 41
do you mean nissan Consult??
also the cat apparently has been replaced during compliance last year, if it has been replaced can it still be blocked taking into consideration that the car hasn't been driven more than 5000kms
https://www.sau.com.au/forums/topic/14988-slow-r33/page/2/#findComment-480319
The Cat should be OK but a dose of super fuel or a bad misfire can destroy a cat in minutes, a solid knock can also break up the guts and send fragments into the system. A good exhaust shop should be able to pressure test before and after the cat and any other muffler in the system. On the cheap grab a dud cat from a complier, Knock the guts out, bolt on and test run, same deal if you can borrow a known good system to test.
https://www.sau.com.au/forums/topic/14988-slow-r33/page/2/#findComment-482074
thanks guys for all your inputs but i took it to a guy i know who has a diagnostic computer and he plugged it in and said that the knock sensor needed reseting and it needed a tune.
does anyone know where the knock sensor is located? and how they tune the cars without an aftermarket management system.
https://www.sau.com.au/forums/topic/14988-slow-r33/page/2/#findComment-487839
anyone??
https://www.sau.com.au/forums/topic/14988-slow-r33/page/2/#findComment-498125
there are 2 knock sensors on the block under the inlet manifold . one is near the front and 1 near the back of the block .u cant adjust the sensors , maybe they had some dirt on them and he cleaned them .
https://www.sau.com.au/forums/topic/14988-slow-r33/page/2/#findComment-498166
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
