Hi
Just wondering if anyone can suggest to me what this problem is...
My tacho is spastic. It reads fine most of the time but then sometime, especially when under acceleration or going over 110klm's it flicks around or reads very inaccurately. Just wondering if it is a bad connection or a bad electrical part of some sort, since it only happens under certain conditions.
So any suggestions on what it might be? How to fix and how much it might cost?
Francesca
https://www.sau.com.au/forums/topic/150073-tacho-is-jumpy/
what model car? if you ever ask a question about your car, tell us all what model your car is.
u have an R33gtst in your avatar but a lot of people on the forum own or ask questions bout other cars as well :(
i had the problem in my 89mdl r32gtr. it was a faulty speedo cable
https://www.sau.com.au/forums/topic/150073-tacho-is-jumpy/#findComment-2799877
u have an R33gtst in your avatar but a lot of people on the forum own or ask questions bout other cars as well :huh:
Hey
Sorry! Didn't even think of it! Its an R33 GTST... Series 2...
https://www.sau.com.au/forums/topic/150073-tacho-is-jumpy/#findComment-2800781
Hey Francesca,
Ron is right, it'll be your speedo cable. The R32s have it as a common fault based on their age, it is surprising to see a series 2 R33 with the problem.
The speedo flicks back from 110kmh to 100kmh? And sometimes bounces around when driving <40kmh?
Good news is that it is a cheap fix. New cable ($90 for R32) and DIY install.
Mark
https://www.sau.com.au/forums/topic/150073-tacho-is-jumpy/#findComment-2801729
Hey
Yeah its just the tacho that is spastic, nothing wrong with the speedo. Its just that the tacho mucks up either under acceleration (not all the time) and at speeds over 110km...
Maybe it does have something to do with revs but its funny that it would as it doesn't seem to discriminate at what revs it plays up at??
Thanks for your help!
https://www.sau.com.au/forums/topic/150073-tacho-is-jumpy/#findComment-2803272
Hey budy,
my '95 GTS-t S1 does exactly the same thing at about 3400rpm. For me it was physically the tacho, not any wiring. I have a brand new nismo cluster and no worries. But you dont need to spend much money to get yours working, there are plently of instrument repair companies around, or source yourself a second hand cluster.
https://www.sau.com.au/forums/topic/150073-tacho-is-jumpy/#findComment-2803460
sorry to hijack mildly - cowie was that speedo cable $90 from Nissan?
It was in that vicinity at trade/SAU NSW member price iirc.
Guys are paying around $80 for fitting but it is an easy job to DIY and take your wife/gf out for dinner instead :)
https://www.sau.com.au/forums/topic/150073-tacho-is-jumpy/#findComment-2811649
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
