not sure if its been covered yet but last night at the top fuel challenge at willowbank qld theo ran 8.95@159 mph on dot tyres.. mark jacobsen also run pb of 9.23@157 odd mph... two of the fastest true 2.6litre motors in the world,and all on street tyres with non sequential shifting gearboxes and HEAVY cars.. CONGRATULATIONS
Edited by easyst
https://www.sau.com.au/forums/topic/150223-theo-woolett-895159mph/
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
    • Who tuned it? Have you spoken to them about the hot start issue yet?
    • injectors were upgraded (1000cc), stock turbo high flowed, return flow infercooler and ecu nistuned before tuned
    • Injectors? Note, there is no way that I would run E85 on stock injectors. They are too small.
