Hey guys, Black R33GTST, 1993 Model, goin for $12,000 ONO. Negotiable. Car has done about 12x,xxx km's and is always garaged. Self serviced every 5,000 k's. Has rego til Sept 07 and is in NSW.
Car is completely immaculate, engine bay + interior. Car has been in no accidents, though the passanger side rear panel was scratched when car was parked at the shops :) , can be repaired if requested. (pics will be supplied soon).
Pretty much all stockers, only mods done to it are the 17" rims, exhaust 3" all the way through from turbo, turbo timer, monz bov, 3pt immobilizer, changed the steering wheel and installed a system w/sub.
Currently no pics available, but will be made available by the end of this weekend hopefully.
Any enquiries call Steve on 0406 136 246.
Cheers!
Edited by Heero
https://www.sau.com.au/forums/topic/150232-fs-r33-gtst-black-93-12000-neg/
no luck attaining pics as digi cam doesnt work =/ sorry, will get them as soon as i can get a cam that works >< might just go buy a dispoable, developed and scanned as a worse case scenario..
