Hey all,
I have for sale a full set of used Yokohama Super Advan Racing SA3R wheels. Very hard to find these rims as they are out of production...
Came off an S14 but will suit almost any application.
Specifications:
Size: 17x8 (front), 17x9 (rear)
PCD: 5 x 114.3
Offset: +35 (front), +38 (rear)
Center caps and valve stems included
Made in Japan
They are in fantastic condition with minimal to no gutter rash and come wrapped in KUMHO ECSTA 235/45R17 tyres. Basically brand new (95% tread remaining).
$1200
$1100
Located in Adelaide, SA.
Can be delivered to your door ANYWHERE Australia wide for $100!!
PM with any questions/queries.
Edited by driftKNG
https://www.sau.com.au/forums/topic/150541-sold/
simmyb: Not gonna take the tyres off man. At the least, might as well use em up for a bit of thrashing or a regency job...
Darkboy: They def aren't 4 hole mate, must just be the angle of the pic.
JAS-25T: They are light mate, but not that light! >_< That is the weight of each rim... Tyre would add another 4-5 odd kg...
Edited by driftKNG
https://www.sau.com.au/forums/topic/150541-sold/#findComment-2806070
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
