Hi,
Hello to all that remember me. It’s been a while... I hope someone local can help me out?
To cut a long story short, I have sold my GTR (pending issue is resolved) but I have been getting ignition problems at high boost for quite a while now. I was showing a customer my car and was getting these boost issues and he had a spare set of ignition coils and a wiring loom from a R33 GTR.... so we changed it over and the same issue was still present. So we changed the igniter pack also but could not get the car started. Turns out that the igniter pack was from a GTS-T and the earth pins are in different locations. So, my igniter pack is now well and truly stuffed cos I can’t get spark from #4 at all and have tried two sets of wiring looms and coil packs all with the same issue.
I have located a spare igniter pack in NSW from just jap for $200. Nissan want close to $800. Does anyone local have a spare one sitting in their garage? I will collect and pay today if anyone can help me out.
Sorry to jump on the forum again only to ask for such things, but its the best tool available to me.
I have also posted in the Vic section.
See ya,
https://www.sau.com.au/forums/topic/150757-need-a-gtr-igniter-pack-asap/
ive got one,
give me a call
cheers
Will be picking up today from Racingline. ActionDan - will let you know if it does not fix problem then you can have it.
Thanks
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
