hey guys.
ive noticed recently, that everytime i wash my car and chamois it, it leaves stains on the paint work, and the only way you can get rid of it, is to poilish it out. :whistling:
as i said, its only been happening since december, after i took it to a place to get washed.
any ideas?
re-spray is on the cards, but what can i do in the meantime? cbf polishing it all the time..
and if you want pics, i might be able to organise some..
car is a Black r32 gtst..
thanks in advance.
jarryd
EDIT: could this be caused by carwashes usuing recycled water?
i might have to do a test at home by using tap water.
f**king water restrictions.
https://www.sau.com.au/forums/topic/151135-white-stains-on-paintwork/
I have a black R33 - dark coloured cars show water stains and residue a lot more than lighter coloured cars.
I find that washing the car in sections and rinsing helps prevent the stains appearing (ie: wash roof and windows - rinse car, wash mid section - rinse car, wash lower section - rinse car). Also the sooner you can get the water off the car with a chamois after washing, the better
If you've still got marks, you could try using Meguiars Quick/Speed Detailer on a cloth and give the car a wipe over...
strange, perhaps its the polish your using or they used.. dried white not clear? hit it up with some tek wax and see how she comes up
i use tech wax to fix it up lol
its kinda dried on. ill try get some pics up.
yeh try some diff cleaning products and see how thtgoes.
i only use meguiars, so i dont think thats it...
is it all over the car and consistant...if only in certain areas maybe somethin has landed upon ur car like a chemical or something...or maybe some1 has sprayed ur car with something nasty
dunno wat else it could be, if it was polish is should be polished back of for "good" once u re-polish the car, only thing else i could think of is maybe after a polish u missed certains spots...left it in the sun and the polish has so to speak "baked" itself onto ur paint , then once u polish it off, the new polish shins it over until its fully come off/sprayed off with water
Edited by Ricos
Yeah thats weird then dude... Real upsetting actually..
maybe hit those spots with a buffer next time? strange if you ask me .. Make sure you hose of excess soaps quickly and always wash your car early morning or night to avoid mid day temps to evaporate valuable leftover water (leaving marks)
hmmmm....must have been this place i took it to then...
but what can i do now, when it happened i took it back the nextr day and they polished it out.
it sucks.
well, re-spray is coming sooner then hey..
thanks for your help ppl
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
