after reading the rules the other day i have registered an account myself i am the owner of this car !!!!!!!:
DESCRIPTION: 2001 model s15 200sx ,originally manual version +australian delivery car (NOT IMPORT)
fully engineered and rebuilt nissan 6 cylinder conversion fully legal in nsw ,massive turbo,custom front mount and fully manualised auto conversion with massive 4 grand stall convertor with transbrake,fully legal in NSW,full 4 inch custom exhaust ,pro ratchet shifter,autometer guages ,fully prepped for circuit and drag racing and just as smooth as a daily driver.
many spares including slicks(circuit and strip),front runners,mickey tompsons 26x 8.5
neat and very clean paint and immmaculate straight body runs on street slicks with 17 x 8 inch toyo r888 allround custom made coilovers with 2 sets of springs for circuit and drags,gtr r33 brakes conversion
this car has run 10.6 @ 128 mph with more left in it eg 10.2 -this car is the quickest street regoed 200sx WITHOUT NITROUS and all paper work to prove it,no more to spend turn the key and drive all day everyday
have the best of both worlds !!!!!!
owes in excess of $90,000 all mods professionally completed no corners cut !!!!!!!
NO TIME WASTERS OR DREAMERS please ,genuine enquiries only .please contact me PETER on 0404866622
PRICE:$50,000
  • 6 months later...
$50k!!! far out... (it's worth it, though I'm trying to make it sound expensive) :)
Interested in a Skyline V35 + cash???
I had a 200sx before this skyline, and honestly, everytime I change from a 200sx, I regret it so bad.
Do you have original motor setup?
Edited by LEXREX
was that the 200sx that was at the syd power cruise?
did a massive power skid, was only just beaten by that lilttle datto ute from memory. it was nice to see a jap car take out all the big v8s
nice car mate and good luck with it.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
