  • Replies 45
NAr not skins, whole new cars, Whiplash has been using an Aston Martin DBR9, & a Ferrari F40 :laugh:
my bad, wrong link
http://forum.rscnet.org/forumdisplay.php?f=1116
gives you an idea where to grab them from.
as it's an official site illeagal copies seem to be off lmits but they still tell ou what to kind of search for.
Cheers
https://www.sau.com.au/forums/topic/152580-gtr-2/page/2/#findComment-2880472
at the moment there is a C6R, Pigani Zonda, Ultima GTR, Mc Laren Longtail for the public. the dbr9 is being made by the same guys that did these and hasn't been released yet link
http://www.austraracing.com/shared/misc/WS...tmasEdition.rar
I'm part of a commercial game development team that does a few free mods for the community hence the f40 which will be released soonish. :laugh:
pics of our F40
http://forum.rscnet.org/showpost.php?p=336...amp;postcount=8
https://www.sau.com.au/forums/topic/152580-gtr-2/page/2/#findComment-2881259
Nice one thanks! 'downloading now'
New times 'starting to get competitive now! :laugh:'
Bugatti: 1:33.810
Saleen S7
I reckon I can shave off another .6 with my current car set up, but might have to further tweak car setting for a better time. It’s a bloody hard track to get all corners perfect, certainly can’t do them all good in a single lap just yet. I just did like 15 laps & my 4th lap was the fastest :|
https://www.sau.com.au/forums/topic/152580-gtr-2/page/2/#findComment-2881373
lol now i might clear off the desk and get the steering wheel out. Will have to use a standard car as the f40 has more power (going into turn 1 at bugatti at 300+) is lighter just badly suffers under brakes and in the aero so i'll keep a level playing field :blink:
have to organize a SAU online race sometime :P
https://www.sau.com.au/forums/topic/152580-gtr-2/page/2/#findComment-2881426
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
