yeah alot of cars out there.. so different from what i saw tonight (sunday) so so so little cars..
well don't be inferior.. hehe I drive a N/A.. I don't feel inferior..cuz I chose it.. N/A (and GT-4 cuz it's AWD) cuz my previous car was an echo.. I don't wanna die trying to controlling a 250kw car.. hehe cuz I've only been driving for 3 years..
cheers
Tha has to be one of the most intelliegent things a novice driver has said .. Congrats... although handling a GTT aint so hard :)
city was very packed on saturday nite. its been 3+ months since I last been there for a cruise in the 34. Didn't come across any idiots and got many compliments hehe
sorry to hear about the windscreen oshy.
I have to say your car is one of the hottest rides around.. wish I could afford that machine!
thanks mate! you are the bloke in the black GTT I spoke to at that intersection right?
Yeap .. Holding up the traffic tsk tsk lol ..
Can I ask what kit was that you run? Im not gunna copy you just interested... hopefully its not what i have in mind.
Love your rims too btw.. never seen them before very different and slides together so well
holding up the traffic is no sin in George St, 99% of traffic is there for bumper to bumper action anyways lol
the front is Impul and rear is Nismo. I wasn't in the mood of puttin on side skirts but I mite be changing my mind and putting on the impuls which are somewhere in the basement. Just need to get em painted.
cheers
I suspect a lot of the hoons can drive their car fast for about 1/4 K in a straight line. Get them onto a track where they have to actually drive with some skill and your GT-4 will pass them while their off in the grass....
Sorry dude, I have to disagree.
Holding up the traffic ANYWHERE is just plain selfish and very f*cking annoying to other road users... EVEN through George Street on a Saturday night.
Explain that to sydney taxi drivers because im pretty sure they dont get that idea... seem to think checking before merging or sticking to the speed limit is just a rule for other people as well..
Sydney taxi drivers are in a (very idiotic) league of their own... Pretty much goes the same for bus drivers - they think they can just push in anywhere, regardless of the number of vehicles around them and the speed those other vehicles are travelling at the time.
Nothing pisses me off more than Taxi drivers who just stop dead in their tracks and think it's OK because they put their hazard lights on! Pricks! I know it's their job and all but they could go about things in a less dangerous way...
so true. happened to me this morning. you're courteous enough to let them get into parramatta road from some quiet street and they pull this manouvre in front of you.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
