  • Replies 100
hehe, yeah they are mighty fine rims! although I dont think the chrome would suit a white car.
Im pretty keen on these Racing Hart CR's im lookin at....what you guys think?
second pic is the rims.....first is my very poor attempt at puttin them on my car using paint....but you get the jist...:laugh:
Got some wheels for sale on aus300zx.com. Check em out and if your interested you can sign up and buy em.
http://www.aus300zx.com/forum/showthread.php?t=258001
http://www.aus300zx.com/forum/showthread.php?t=253335
http://www.aus300zx.com/forum/showthread.php?t=257874
thanks for the links...but 2 of those are 17's, im after 18's, and the 18's in the last link are in Bris and not really my kind of style rim.
was Aaaron (rampant.net.au) quick in responding to your enquiry? I've yet to hear back... is that normal? i'm not too concerned, because i know some of these car places are uber busy... but i'm thinking i might not have put down the correct email address? and i think i read that they would try to respond within 24 hours?
Just incase you sent your enquiry to the wrong address its:
[email protected]
In my experience, he usually responds very quickly. I for one have delt with him many times and he ALWAYS comes through with the goods. Both in the time he said it would take, and at the price he said it would cost. Cant beat that!
I wouldnt hesitate to recommend him to anyone, and I know i will be using him in the future.
when I first sent him an email, he replied within half an hour (it was around this time I emailed him (btw 8-9pm). Since then sometimes he has taken a little while to get back to me. He's been of great help with many questions I was asking about rims for my ride, such great help that I've now bought rims off him.
Highly recomend going through Aaron to get whatever your after, as many people have said...he can pretty much get whatever your after. I know he'll be my first stop as soon as Im after anything else.
cheers
i've actually dealt with aaron before in a very round-a-bout way... but never used the website enquiry form before... i might have put in wrong email address... i'll check my mail when i get home.
are you going to let the cat out of the bag abscent? or are we waiting for pics? >_<
yeah, i'll be keeping my black BBS 17's for some r-compound rubber eventually...just cant afford the rubber right now. Was considering some 16's for track work cause the rubber would be cheaper, but i dont think it'll be that much cheaper?
What sorta Rays you looking at? So many types/colours would suit your colour car....
I got a call Wednesday from Aaron saying my rims were in, but he wasnt happy with the gutter rash on them, so he's getting them repaired for me (no extra cost), what a champ! I'll be sure to post up some pics as soon as there on my car.
I want TE37s i guess...he will look for some and see what colors i can get 2nd hand. Then we will suss our some r-comps. Hopefully get this done before the WRX PI track day.
you dealing with him too KJ? i'm being snubbed :) someone mention me in passing please (dude who had dealt with gareth from j-spec)
yeah he is great...we sent like 10 emails last night to each other...must be wrong email or somethoing mate.
i got a reply just yesterday, but he's totally swamped with a new container that's arrived.
i've actually dealt with him once before, great guy to work with.
i wasn't fussed, just wondering if he might have been on holiday or something.
it's not like containers are little things :P
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
