Gday guys and gals,
has anyone here purchased an Exedy Lightened flywheel? is there just the chromoly one or is there an aluminium one too? does anyone know how much they weigh and price as the website has limited info. shot off an email to them last week but no reply as of yet.
heres the link
http://www.exedy.com.au/catalogue-details.asp?id=38999997
stuck whether i should buy an exedy which is local(no waiting) or get a Cusco chromoly one of nengun (14day wait). anyone here running the Cusco unit?
cheers
https://www.sau.com.au/forums/topic/153060-exedy-flywheel-info/
  • 4 weeks later...
sulivan whos a trader here selling exedy kits informed me that the flywheel is chromoly steel and weighs a little over 6kg which is what im looking at getting installed in the next few weeks.
exedy customer service is useless. i shot them 3 emails regarding the flywheel and hd cushion button clutch with no reply at all. maybe my questions were too hard to answer...pft
hahahha
yea im just assesing if its worth it... how much it set u back?
im lookin at the sports organic, i mean the fly wheel would be good on teh old r20 wit its poor form down low off boost, but ive herd its not worth the momeny for the verry small increase in performaqnce gains, i dont really drag race,
i am more downhill run old pac style,
cheers
brett
yeah im not expecting much but i figured while im doing the clutch ill do that also. i dont want it too light as id still like to keep some inertia so 6kg is good for me. the shop im going to is getting it trade for me around $600 gst inc. i could be a tight ass order from nengun and save $100bucks but then id have to wait for it. dont mind paying abit more for not waiting and domestic warranty.
Edited by (B1) MR_fanny
They are a solid one-piece forged chrome moly steel and for memory they are about 6.8kg (something around there) very good upgrade if you are looking into track/drag and also for drift.
Im pretty sure that EXEDY only make the one lightened flywheel (no other material) but i can check that out if you like (my brother is an EXEDY dealer) but it wouldn't be until Monday :happy:
(oo\__4Door__/oo) if you are just looking at one of these to help bottom end then i wouldn't bother personally. I take it you have a RB20 from your post correct??? Is it stock or mods (if so what mods) true you will notice a difference with the lightened flywheel but not enough with other upgraded other parts as well. For the money you would be better off installing a set of cam gears to help that bottom end/mid range :(
GMB
engine mods are just basic, zorst, fmic, pod wit a box, yea nahh that was i was sayin for the money u can get alot better gains, im goin to get the stocker machined, yea i like the idea of the cams ha ha, it was just wile it was down i thought id investigate, cheers thhough
brett
  • 3 months later...
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
