Hi guys,
Decided to make some space in the garage.
Tein superstreets suit R32gtst. $SOLD
Bought new less than 1 year/5000km ago. These are the aus spec model with the rear springs swapped for a shorter 5kg/mm spring and helper spring added to give more adjustment below 330mm. Front's are still 4kg/mm. Height and damper adjustable. No knocks, rattles or leaks.
Super Longchamp VR3's 17 x 8 +30 and 17 x 9 +35 with tyres $SOLD
215/45-17 dunlop dz101 front with maybe 20% tread left and 235/40-17 rear GT Champiros near new. The wheels are multistud 114.3 pcd. 2 rims perfect, no gutter rash, 1 rim has a slight nick maybe 1cm long, and the p/s front has a some gutter rash. Both fronts could use a polish to remove some minor corrosion on the dish. All 4 centre caps are included.
More pics available on request
cheers
Dave
Edited by BHDave
https://www.sau.com.au/forums/topic/153521-sold/
  • 4 weeks later...
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
