i just replaced my front and rear rotors and i was thinking of bleeding my brakes but now my brakes pedal has gone all the way to the floor.
i went to the Passenger rear side to start the bleeding process and no brake fluid came out.
so what do i do?
do i have to start bleeding from somewhere else?
this is how i did it
i removed the rotors and calipers (to paint) from the driver side first, then the passenger side, then the driver rear, then the passenger rear.
i also realised that my driver side brake line (the line from the caliper) is leaking and i will need to get this replaced.
Edited by theevilworld
https://www.sau.com.au/forums/topic/153582-brake-bleeding/
to make brake bleeding easier and to do it by yourself.
unscrew the bleeder nipples and put thread tape on the threads.
then with a drink bottle run a hose into it. then simply pump the brake pedal. this way no air is sucked in threw the threads.
very easy and you can do it all by your self.
https://www.sau.com.au/forums/topic/153582-brake-bleeding/#findComment-2858137
Start from the passenger rear as you did then go to driver rear, passenger front then driver front (basically from furthest from the master cylinder to the closest).
If only air comes out while you are bleeding then just keep pumping. Contrary to the above a simple hose is no good, buy a one man bleeder hose from repco or supercheap (cost maybe 5-10 bucks). Unless skylines have a check valve built into the caliper (unlikely) you can draw air back in through the hose when you release the pedal if you don't use a bleeder hose. You need to close off the nipple before you lift the pedal, the one way valve does the same thing. Thread tape isn't a bad idea though, you shouldn't get air in through the threads but it's better to be safe than sorry I guess.
Ideally when bleeding brakes you should use a different coloured fluid so you know when you've flushed them completely but if your fluid is old it will probably be darker than the new stuff so you should still be able to tell.
Take the top off the reservoir, hook the hose up with the other end in a bottle and undo the bleeder nipple. Pump the brakes until the reservoir is NEARLY empty (not fully, never let it empty below the fluid pickup) then fill about 1/4 with the new fluid. Pump the brakes another few times until the reservoir is nearly empty again then fill it about 3/4.
Now get another bottle and swap them over on the hose (still on the same caliper). Give the brakes a couple more pumps and check the colour of the fluid to be sure the new fluid is coming out. If it's not just keep pumping until it does. If new fluid is coming out, switch to the next caliper and top the reservoir up if needed. Hook the hose up, open the nipple, pump until new fluid comes out then close it up and repeat for the other two.
Hope that helps.
Edited by Astaroth
https://www.sau.com.au/forums/topic/153582-brake-bleeding/#findComment-2858148
you still gotta close off the nipple. it still sucks in air threw the threads.
Right - so you have to close of the nipple however you're suggesting using an open hose?
the whole idea is to keep the end of the hose imursed in fluid.
If you'd actually read his post like a good little boy you'd see that when he started bleeding the brakes no fluid came out, only air.
By putting an open hose into a bottle with fluid and pumping you will suck old fluid back in rather than air. And making sure the hose is immersed in fluid is kinda difficult when you're on the other side of the car. A bleeder hose is maybe five bucks and makes sure the job is done properly - if you want to cut corners with your brakes then be my guest but seeing as though they're the only thing slowing the car down I think I'll do things the right way.
Edited by Astaroth
https://www.sau.com.au/forums/topic/153582-brake-bleeding/#findComment-2859764
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
