New guy...
Guest Skyline Fan 01
Hey everyone,
I'm new to this whole forum thing, so I've got no idea really what i'm doing. Guess i'm just tryin to find my way around.
One thing is i know basically next to nothing about cars. That is, the insides of them, like engine specs and all that. So, if anyone can give me a run-down of what all the fancy terms mean, then that'd be nice.
If any1 has any pointers 4 me about forums (this 1 in particular obviously) then it'd be greatly appreciated.
Also, I've got around 17-20k for my first car. Any suggestions?....Doesn't matter what. Doesn't have 2b a Skyline necessarlily.....but preferably, of course.
Anyway, thanks heaps.
https://www.sau.com.au/forums/topic/15359-new-guy/
  • Replies 43
if u arent really concerned about what car u get then you should just consider the economic and use factor, will u use it everyday, how far will u travel etc. Skylines do tend to be a bit heavy on the ocket for petrol, specially if u just lurrrve pushing that accelarator. i suggest sum front wheel drive toy, good fun, handbrakies are good fun too hehe
https://www.sau.com.au/forums/topic/15359-new-guy/#findComment-314624
ok cool......thanks for that everyone....that kinda gets me started in the right direction. At least i've got some idea of what to look for now.
I'm still not sure how much i'll have to spend, cause i'll have to wait as the olds are tradin' in mums 2001(?) pulsar +, so i'll have to just see, but that's the rough amount.....
And i'll definately be asking about what some terms mean, cause my friends know their car jargon, but like i said, i've got no idea, so thanks heaps for that as well.
Also, what's the easiest way to tell the difference between the R33 and R34 Skylines?
https://www.sau.com.au/forums/topic/15359-new-guy/#findComment-315111
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
