it did it again!
pm'D!
may i see pictures of the back of the car?
here is a pic of rear, As I said I need a stock sr20det 180sx for a Sil80 project i'm building and really cant be stuffed doing engine conversion's but if you have pics send them and we will see. it would have to be worth it.
Edited by Rifleman
https://www.sau.com.au/forums/topic/154004-please-delete/#findComment-2875410
ill swap u my sileighty, its a CA auto,
Sorry, its a nice sil80 but i need a sr20 man, not interested in engine transfers.
Just looking for a 7k to 8k man sr20 180sx or sil80 or cash. thanks anyway mate
Edited by Rifleman
https://www.sau.com.au/forums/topic/154004-please-delete/#findComment-2878937
and if i add cash for you?
y are you selling it for 6k, whats up with it? arnt you in ACT any way? I'm in Melb.
Price drop $10,250 problems should be fixed next week. Need cash for Motorbike
Edited by Rifleman
https://www.sau.com.au/forums/topic/154004-please-delete/#findComment-2881330
Sorry to shit on you'r parade mate, but the only sr20 180 manual for 7 or 8k would be a track car.. cant get it on the road.
The cheapest SR20DET manual in DRIVABLE condition would be a s13 silvia FROM 10k+ 180 from 12k+
Ps where and how much did that fire extinguisher set you back?
https://www.sau.com.au/forums/topic/154004-please-delete/#findComment-2882688
Ok first of all i posted this ad to sell or swap my car not listen to guys arguing about price. A mate just bought a DRIVABLE s13 silvia manual SR20DET for 4k and will have it on the road for less than 2k more so next time you wanna criticize some one about what they want, keep it to yourself.
And the fire extinguisher was given to me by Work. dont know price.
Edited by Rifleman
https://www.sau.com.au/forums/topic/154004-please-delete/#findComment-2884266
Yeah mate don't have a sook, im just letting you know before you buy a lemon.
https://www.sau.com.au/forums/topic/154004-please-delete/#findComment-2885940
No Swaps anymore, just cash. Need it for motorbike and pay off some debts
Price is Neg, make a sensible offer.
Have the HICAS Lockbar and Nolathane bushes sitting here waiting to be put in. (f**king Work!!!)
Edited by Rifleman
https://www.sau.com.au/forums/topic/154004-please-delete/#findComment-2896040
BUMP, off topic any one know how easy it is to make a Sileighty. Is it just bolt off 180sx side fenders, front bar, lights and hood and just swap and bolt on silvia parts or are there some fiddly bits i need to know off?
Edited by Rifleman
https://www.sau.com.au/forums/topic/154004-please-delete/#findComment-2902480
Sony xplode 12" 1200watt Sub and 2 Amp's
(sony xplode 4 channel for front and rear speakers, 1000watt pioneer single channel for sub) now come with car. cant be stuffed removing them and ill have no need for them after i sell it. your gain i guess
https://www.sau.com.au/forums/topic/154004-please-delete/#findComment-2918842
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
