Someone might able to give me some idea, thanks..
I found a set of Tomei cams, 264 IN/EX..and the IN cam stated support NVCS..however from my understanding is the NVCS won't work if you change to after market cam gears...so does it mean to let the IN cam works well, I need to use the stock cam gear for IN cam and after market cam gear for EX cam?
thanks..
Phillip
https://www.sau.com.au/forums/topic/15438-nvcs-on-hi-camhelp/
Hi guys, we have Tomei cams (256's on both inlet and exhaust) in the R34 GTT, it has an adjustable camshaft pulley on the exhaust and runs VVT on the inlet. It makes 260 rwkw using a GCG Hi flowed R34 GTT turbo. The camshafts were designed to work with the VVT, so it has a very nice power powerband. They only added about 8 rwkw to the max horsepower but around 20 to 25 rwkw through the range. They also removed that flat feeling you get on high powered RB25DET's just after they come on boost. Off boost performance is also noticeably improved.
Having driven this car a number of times on the street, drag and circuit, I reckon it is simply the best all round standard internal RB25DET I have seen.
Bottom line, if you are going to put some new camshafts in your RB25DET, then buy ones designed to work with the VVT, I reckon it is definitely worth it.
Hope that helps.
Hi, GTS-T and SydneyKid..thanks once again..
So Sydneykid..does the R34 GT-T you refered, pickup the cam shaft and cam gears bolt on together and the VVT works straight away without modification?
the reason I ask is that the cam shaft I have specfied / stamped as support NVCS, but I could not find the Tomei cam gear support NVCS..
I rang some workshop, and been told need to machine the tomei cam shaft / tomei cam gaer to support factory VVT / NVCS, and this really confuse me..
did I overlook some where...thanks in advance..I will try to take some pics of the cam shaft and post tonight..
I think Sydneykid is using the stock inlet cam gear, as this is the one that uses NVCS, and any adjustbale cam gear on the exhaust side, as it doesn't affect NVCS.
It will depend on whether your after maximum power or streetable power. If your after streetable then follow Sydneykids directions.
See'ya:burnout:
This is son of Sydneykid
hey sidewaymambo
Between the two of us i can definately say that we have never seen an adjustable cam on the inlet of an RB25DET. So that answers that question.. it is simply never done.
I believe that VVTi is a similar to adjustable cam sprokets, on VVTi makes them infinitely adjustable... but i ain't overly sure
Son of Sydneykid
to SydneyKid and GTST:
I have been thinking this as well...and I believe the best way is install the IN cam gear and compare to the stock cam gear..IF my turbo (T67/TD06-25g) is going lag as hell, I want to see what NVCS can help at low~mid range, and what after market cam gear can do. Does it sound like a good plan? What you recon?
My mods at moment are stock engine with stock boost, Trust cooler, Pod filter, 3" Fujitsubo system , PowerFC
Parts ready to bolt on: TD06-25g, trust ex-manifold, Front pipe, Nismo 550cc injectors, large fuel pump, fuel regulator, Q45 AFM, ProfecB..
But sure, I will have those mods on get a figure and graph and compare after the cams / gears on..looks like a long way..we will see..
Thanks to all.
to steve: if VVT = NVCS, then as first post, that Tomei make them..
at bottom of page..cheers..
http://www.tomei-p.co.jp/_2003web-catalogu...2_cam_RB25.html
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
