Ok people.
Some of you might of seen this before, but i have never heard of it so im just wanting to know if this stuff works or you have tried it for yourself.
This product claims to do the following.
Reduce engine heat load
Increase available horse power
Increase top end RPM
Improve engine response
Reduce turbo lag
Makes boost come on earlier.
And many other claims
They say its like having a high flow turbo and that they use it in V8 supercars and drag cars.
They say its the secret of high performance engines and you cant buy this product over the counter.
WHAT DO YOU THINK. :happy:
Edited by subzeroR33
https://www.sau.com.au/forums/topic/154420-roil-gold/
there was a huge thread about this about 2 years ago.
i have a bottle at home, just need some time on teh dyno to see if it changes anything
HINT : do not use it in a gearbox (it can be used) but it reduces the syncro's ability to slow the gearset down for a smooth engagement
https://www.sau.com.au/forums/topic/154420-roil-gold/#findComment-2872504
why is it people are SO quick to crap on a product with high claims rather than accept it or even give it the benifit of the doubt
i read most of that thread and everyone that used it didnt say a bad thing about it
i think i might try it
just curious as to who is a QLD supplier (central queensland if possible)
RellikZephyr
https://www.sau.com.au/forums/topic/154420-roil-gold/#findComment-2876758
Dont know anything about that product but personally I use Redline, used in everything from street cars to top fuelers...ask Jim Read, dont believe what the decals on his car say :)
Well it claims to do alot of good things for performance.
Sounds to good to be true????????????
https://www.sau.com.au/forums/topic/154420-roil-gold/#findComment-2877407
This is a little back ground on additives, I dont claim that Roil Gold is the of this type additive but here we go.
Alot of oil additives contain chlorinated hydrocarbons which are very slippery, which is good. However, when you put these types of additives through a number of heat cycles the chlorine molecule can break off and become attached to water molecules and you've got hydrochloric acid...which is bad.
If you look around the interweb you will find a "company" called Neways, these guys sell cosmetics...and distrubute Roil Gold. Check out their offer of a ""business opportunity" :)
In the end if you need an additive in your oil maybe you need to buy better oil.
https://www.sau.com.au/forums/topic/154420-roil-gold/#findComment-2877836
my next door neighbour is a seller of this product fro years and has used it in the Saabs for ages...funny enough they have gone though more GBs than any ppl I know. Considering their have low power outputs...I always thought there was somthing suss.
Do an oil or UOA test after 5000km and see how its performing...if it all; looks good then there do another at 10,000. if no dramas and the oil is still going strong then probably not doing any harm.
I dont belive subjective tests and personal opinions...generally they are biased esp if ur selling the product..and LOL and the Roil video they send out. I remember watching that in 2004 and picked so many issues up with them on that alone. But good effort for trying.
I have no opinion of this..I have no proof and the UAQ results...I would have to look at them again but they was a major flaw...cant remember what is was. Similar to that of the RP tests.
Intrresting to see how this sheers over time. Any reports form the guys using it from 2004?
https://www.sau.com.au/forums/topic/154420-roil-gold/#findComment-2877942
WHAT DO YOU THINK. :laugh:
RPM is limited by the ECU, so there is no way it can improve that. 100% bullshit.
Ultra slippery oil will gain you what, maybe a couple of percent? A high flow turbo it is not! Considering a modern roller bearing turbo, you would have to be running grease through it to make a difference in spooling RPM, or spooling speed. The air rushing through it is much more significant than the small contact patches with oil on them in the bearing.
You'd think that if it was so brilliant they would sell it wherever possible. Sell it to an oil company and get a commission off every oil bottle sold with your additive. That would be the smart way of going about something genuinely revolutionary.
No, I'll just stick to a good quality full synth oil thanks. Not worth the risk of pouring chlorine into my engine.
https://www.sau.com.au/forums/topic/154420-roil-gold/#findComment-2878252
I've gone through some testing with Roil Gold ( bench testing and in car testing ) and IMO, don't use it in your engine, gearbox ( man or auto ) or diff. One place I've found that it works a treat though, is in the power steering.
https://www.sau.com.au/forums/topic/154420-roil-gold/#findComment-2879698
would you like to detail ur testing more? pm if u like. id be intrested.
https://www.sau.com.au/forums/topic/154420-roil-gold/#findComment-2879771
We did the bench test ( as they did / do with the machine with the bearings and the torque wrench etc ) and the product does work in that situation & under those conditions ( we tried everything to fault it ).
We added the Roil Gold to the 1st test engine ( a reasonably healthy RB20DET ) and ran the car around for about 2 months and then put the engine through it's paces ( track time ) and #3 big end bearing let go on the 1st warm lap ( coincidence, maybe ? ). Our plan was to put it on the dyno but the track opportunity came up first so we took it.
We then added the Roil Gold to the 2nd engine ( another reasonably healthy RB20DET ) and ran it for about 6 weeks. We performed a leakdown and compression test pre and 6 weeks post the Roil and found that post gave us a drop in leakdown results but the comp test stayed the same. Put the car on the dyno and there was no measurable performance gain from pre Roil. The only thing we found that it had consistently increased was the spool down time of the turbo from engine shut-down ( 18 sec pre to 26 sec post Roil ). We decided not to invest any more time.
We added it to a couple of gearbox's and found that it actually resulted in more selection issues since the syncro's didn't want to mesh as well as with just 80W-90. Considering how it went in the gearbox's, we decided it would not be wise to add it to any LSD oil.
The only reason I know it works great in the power steering is because I've added it to many cars and it has shown benefits in the way of more free operation and noise reduction ( it completely silenced the near dead power steering pump bearings in my old man's Patrol ). :laugh:
I've discussed my results with many people and have had all sorts of "if's" & "but's" and a few hostile accusations so don't take my opinions as gospel. As far as I'm concerned, try things out for "yourself" and you'll then get 1st hand results as opposed to what anyone else says. Roil Gold seems to work really well in the test conditions that are used to demonstrate the product but just didn't seem to follow through in some "other" conditions.
https://www.sau.com.au/forums/topic/154420-roil-gold/#findComment-2879885
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
