TOMMY KAIRA R32 GTS-T
Engine
-550 injectors
-avcr
-power fc
-malpassi fuel pressure reg
-hybrid monster cooler
-custom catch can
-custom inlet pipe
-hks 2530
-hks external wastegate
-K/N pod filter
-bosch 040 fuel pump
Drivetrain
-rb25det gearbox
-5 puck clutch
-cusco 2way lsd
-hicas lock bar
Other Stuff
-panda paint job...black/white
-koya race techs.......soon to be jap 18x10 -4 and 18x9 -4!!!!!
-jvc touch screen cd player
-25mm vented fibreglass front gaurds
-slightly flared rear gaurds
-t2 style carbon fibre bonnet
-bn rear and side skirts
-bomex front bar
-ISC COILOVERS
-boost gauge
-tommy kaira steering wheel
-tommy kaira pedals
-VELO GP90 SEAT
-SPARCO HARNESS
-adjustable front camber arms
-adjustable rear camber arms
-adjustable front castor arms
-custom straight through exhaust
-white face dial kit
-24mm front whiteline sway bar
-22mm rear whiteline sway bar
-front strut bar
-rear strut bar
LOOKING FOR $23,500.- CAR COMES WITH 4/5 MONTHS REGO-NO TYRE KICKERS
Edited by lunaticR32
https://www.sau.com.au/forums/topic/154421-sold/
sorry, but, what exactly makes this a tommy kaira car? Build number? anything?
Hey, Tommy Kaira made 2 kinds of cars, one that has build number,seats,wheels,engine parts, the works etc. The other one just has bodykit, steering wheel, foot pedals etc etc...thats what this was was, the bodykit was sold about a year ago and replaced with a BN/BOMEX kit.
Ryan
https://www.sau.com.au/forums/topic/154421-sold/#findComment-2878540
  • 3 weeks later...
I reckon if this is such a unique car, it should of been left as an orginal tommy kaira with the optional features. Have you got proof to justify that is an actually TK edition?
anyways, I have to say its a very sexy looking car and practically just another modded R32! :rofl:
https://www.sau.com.au/forums/topic/154421-sold/#findComment-2942695
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
