Anyone Going To The First Final At The G?
Anyone? Its next friday... im trying to see if i can get some of these delivered before the game so me and my cousins and mates can go :happy:
http://www.retrocricket.com/newzealand.html
stylin...
notice they also have aussie ones as well.
narkeh i couldnt imagine anything dull-er to do, than watching a bunch of yobbos standing around the football oval (where usually real men play real sport) watching one dude do all the work going up and down the oval throwing a round plastic object at another dude holding a piece of timber, on a fine melbourne summer evening... haha
dont get me wrong cricket is good, in fact great when i am not watching it..
:P
BINGO!
whats round and plastic tho? i know theres something round and leather.
looks plastic to me ;)
all about the beer?? u guys like drinking beer while looking at men rubbing their balls?? :O
there is this new invention called beer gardens with coustic tunes and full of mini skirt clad females... :P
Our mission in life is simple. We want to enjoy a good beer with mates, catch a few rays of sunshine, take the piss and to pay recognition to some of the more memorable moments in New Zealand sport.
lol
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
