  • Replies 119
Ewww... Bad memories from playing gigs at UN/DCM's...
I REALLY hope your nights there are better than my experiences there, Mars!
wot happened to ya champ??
BTW... guest list here
http://www.skylinesaustralia.com/forums/in...howtopic=158656
  • 3 weeks later...
I'm gonna pass on transmission... I'm getting a little old for banging trance :D
Although I do hear that they have a house/electro stage there this time around... It'll either be completely empty, or full of munted 'massage trains' of people using it as a chillout room :)
