For sale: 1992 Nissan 180sx NSW
Asking Price: PRICE DROP $14800 neg or looking for trades r32 prefered
Killometer's: 120,000
Manual or Automatic transmission: Manual
Engine Type: SR20DET 2.0 RED TOP
Modifications
Full body kit Veilside side skirts and rear pods and a C-Speed Front bar plus rear wing professionally removed
Custom Blue metalic paint
17in rims
Climate control
JVC MP3 CD player
two Kicker 7x10's
two JL 6x9's
Electric windows/Mirrors
Alarm system central locking
Auto technica steering wheel
Turbo Timer
Short Shifter Kit with Cutom Gear Knob
Interior black light neons (not currently hooked up but installed)
HKS Pod filter with custom head light air intake
3in exhaust from catback with 31/2in Cannon
Lowered on Fully Adjustable G4 Coilovers
Exeddy Heavy Duty clutch
Greddy BOV
T28 Ball Bearing turbo
Complianced: Yes
Registration: Yes 16/7/08 expires
Location Wagga Wagga NSW 2650
Contact detail's Joel Roberts 0439465274 0269263208 [email protected]
Edited by joe1_4
https://www.sau.com.au/forums/topic/155342-nissan-180sx-for-sale/
  • 1 month later...
  • 1 month later...
  • 4 months later...
  • 3 weeks later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
