Looking for an R33 GTS-T no more than $11,000
-Must be manual and not Burgandy or Red in colour.
Please send pics and specs to [email protected]
Will also swap my VL Calais Turbo for R33 GTS-T http://www.calaisturbo.com.au/showthread.p...041#post1284041
Thanks
Edited by BillyMako
https://www.sau.com.au/forums/topic/155627-wanted-r33-gts-t-manual/
im in sydney. could probably work something out in regards to you having to come over here so probz take a little more out of the asking price.
  • 4 weeks later...
'93 R33 GTS-T 178,000k's
5sp
10,000k's on the timing belt, other belts, tensioner/idler bearings, radiator core and water pump.
12,000k's on the rims and tyres (18" AMG ones)
15,000k's on the clutch (just OEM one)
600x300x76 FMIC with 3" piping
32mm 2 row rad (std is 18mm 1 row)
exhaust
dual stage boost controller
oil changed every 5k kms along with filter.
everything runs fine.
However it has some damage and 2 panels are a different colour, the guy before me tried to fix some scratch marks.
Got a quote for $750 to fix it the rear end and re-align it all (no painting factored in though cause it'll be best to fully respray it anyway).
Comes with a new front bar.
And also big dent in rear bar where someone reversed into it or something, should just need another rear, might be able to get the dent taken out, don't know.
And the windscreen has a far crack on the passenger side (passed rego twice like that though)
It's all booked in to be fixed up, but yeah if your handy with a spray gun might be worth it.
looking around the 10k ono mark.
Edited by Rudager
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
