Hey guy's
Looking at sourcing a calper rebuild kit for a set fo R32 4pot fronts. They arn't going on a skyline so I don't have a VIN number which is making my life a little harder then it needs to be! :)
Where do you just buy your kits from? is there a trader that can supply me one without supplying a VIN number?
Any help would be golden.
Cheers!
https://www.sau.com.au/forums/topic/156647-caliper-rebuild-kit/
just had mine overhauled... my mechanic had them sent away to a caliper specialist.
basically they replaced the rubber boots, pistons and resleeved the calipers, took the whole thing apart and cleaned the whole lot out. although i cant help you with the kit - i can help you with costs.
fronts $195 (pair) not incl. labour
rears $165 (pair) not incl. labour
Front rebuild kits are either:
SJ6070
or
Protex 210E0011
approx $40-50ea
Rear kits:
SJ6024
or
Protex 210E0103
approx $70-80ea
These kits do only 1 caliper so need 2 of each.
Try ABS in the phone book, Race Brakes Melbourne or Sydney.
Edited by VHR32
mate i thin k u got ripped off i got mine done at brakes plus for 4 $160BUT I TOOK MY CALLIPERS OF, that was the fronts aswell
according to the guy above me, not really.
that said labor is the big killer in these kinds of things. with most mechanics charging $60-80/hour the costs easily add up.
price sounds ok to me, I got a price a couple of years back and to replace the pistons(genuine) was a $100 each, which is $800 just to rebuild the fronts + seals+ labour - wprst case scenario- His price doesn't seem too bad considering the types of brakes they are.
I got my caliper kits today.
Front rebuild kits: Protex 210E0011 $35ea
Rear kits: Protex 210E0103 $ 30ea
They were single caliper kits (so 2 of each needed)
These fit all Nissan front 4 spots (excl Brembo and some R34?) and rear 2 spot calipers. WRX also.
ABS told me SJ6070 were to do both sides (not 100% sure about this though)
I previously ordered SJ6024 (Japanese TRW/Lucas) and they were single caliper kits.
Edited by VHR32
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
