I got a r32 very cheap (2000) because it was not complied & needed a turbo to get it complied. I have a friend who gave me everything to convert mine to turbo & its now complied (he went rb25/30 & had it all sitting there) but I'm wondering how hard it will be to make good power (about 200rwkw).I will be doing all the usual mods but was wondering if anybody else here has done it & how much boost can they run etc.
https://www.sau.com.au/forums/topic/157448-turbod-na-rb20/
I did the same thing to an old na VL about 6 years ago. it made 175 hp with 7.5psi. made it with a stock na ecu, auto and injectors. It was no power house, but the higher than turbo compression ratio made it snap onto boost at about 2100rpm. it had a very flat power curve and very strong torque. the only thing i had to do was reset the timing to 10.5 degress (because of the na ecu). it made 207 hp on 9psi with water methonal injection. No intercooler.
Wot i'm saying is this, anything with a sound mechanical base usually works fine. Stressing an na engine a fair way may require some careful thought and planning.
I would check rod and piston strength, injectors wont make the 200kw so they will be goin anyway, ecu has to go get tuned or swapped. cams? valve springs could pose an issue.. the list goes on..
Any other thoughts.. :)
https://www.sau.com.au/forums/topic/157448-turbod-na-rb20/#findComment-2923717
Dont hear of the RB20 being NA--> turbo that often.
In a sense it wouldnt be too bad as the RB20 does have a fair hole.
If you limit it to 200rwkw the compression shouldnt becoming a major issue.
Tuning will be the key, as it is for any setup :)
https://www.sau.com.au/forums/topic/157448-turbod-na-rb20/#findComment-2923731
Already checked out the rb20 upgrade thread quite a few times & have 440cc injectors on order,fmic,the car already has an exhaust,have a bosch 070 fuel pump & will run a surge tank,will get a bigger turbo in the next month or so,will just get the stock turbo computer & get it tuned (mine is still running the na computer),will get a split dump soon etc.Just wondering if the higher compression will affect how much boost I can run,will I have to keep it low or decompress it to wind some decent boost in?.
https://www.sau.com.au/forums/topic/157448-turbod-na-rb20/#findComment-2923738
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
