hey guys
unfortunately i have decided to part with my beloved skyline as it is not financially viable for me to own one at this present time.
It has just under 50 000kms on the clock, and i will not be driving it much during the sale period
The car is located in brisbane
The Price is 25 000 Final price drop
now down to the nitty gritty
i was first owner of car from japan, purchase car from the sponser of this site aussie car compliance
the car has:
sony head unit mp3 player
rear sony front stage 2 ways
front 3ways alpine DDdrive
auto watch immobiliser/alarm with a turbo timer
brand new 19inch koya wheel and tyres, black centre with inox lip not even a month old
from japan came with: Kyb damper adjustable suspension
full 3inch mandrel bent exhaust, 3 months old
short shifter (with it from japan)
Other then that completely Stock, no engine work
if you are interested please contact me here with a private message
or email me directly at
[email protected]
Edited by Jaker34
https://www.sau.com.au/forums/topic/157477-sold/
hey mate
Pictures added, sorry for poor quality they are just a quick job on my phone
no pictures of interior but trust me it is as good as the exterior
there wassnt enuff light for interior pics
anyway as you can see it is immaculate,
Edited by Jaker34
https://www.sau.com.au/forums/topic/157477-sold/#findComment-2931361
Very tight... looks great! the only thing is the colour! ive had 2 white cars in a row an s15 and a soarer n i was adament that i wouldnt make it a 3rd this time round (although white 34's do look hot) neways ill keep lookin but if i dun find what im lookin for i might end up given ya a call
gl wif the sale man
https://www.sau.com.au/forums/topic/157477-sold/#findComment-2936008
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
