Just need to know where i can go to fix the problem i have with my r34 or if anyone can tell me what the prob is.
On the dash it says tcs off and to the side it says slip, how do i fox that??
And my air bag light continously flashes?
None of the 3 centre guages work..fuse? any feedback appreciated
https://www.sau.com.au/forums/topic/157776-r34-questions/
tcs = traction control system? :wave: how do you turn it on? :(
is your r34 4wd? the slip light comes on when the road is slippery/wet :D
try this regarding the airbag light- have your drivers door open, turn the key on to ignition and within 5 seconds press the door light switch 7 times. should make the light go away :)
Edited by R-SPEC
https://www.sau.com.au/forums/topic/157776-r34-questions/#findComment-2930525
Im not sure if its 4wd i dont think so i think its rwd how can i be sure? And there is a swicth that says tcs below the steering wheel and im flicking that but its not doing anything. i bought the car from an auction last week and just noticed s few little problems
https://www.sau.com.au/forums/topic/157776-r34-questions/#findComment-2930673
Sounds a bit dodgy..the airbag light could be coming on because it's been in an accident, had it go off & hasn't been reset properly? The other things..I dunno
If I'm not wrong if airbag went off and not fixed properly, the car cannot start at all...but the car do sound dodgy yeah...
check if the throttle body in your car has 2 or 1 wire. Also try look from behind the car and see if there is a short bar attach relatively close to the suspension which is aftermaket (generally colourfull)_..
check if the wirings in the middle is done properly..I have't done this yet..but I'm pretty sure to get to the triple gauge you have to use a screwdriver to pry out the air conditioning vents (under the tipple gauge) from the side. after it's out there'll be two screws holding the gauges from the front....there is this DIY site for R34 I forgot what it's called....
https://www.sau.com.au/forums/topic/157776-r34-questions/#findComment-2931167
Took the car to my mechanic and he reckons i need to do a diagnostic test and re map the computer or something like that..... He seems to think because of all the mods sometyhing may have been re-mapped which would cause the slip light tcs light and the airbag light all to be on. I got NO idea where to start and how to fix this problem is really givin me the shits. I got the car from auction last week so i got no idea really whats been done to....
https://www.sau.com.au/forums/topic/157776-r34-questions/#findComment-2936028
1. what computer are u running ???
if u are piggy backing then the factory computer is probbly just chucking a fit cuz not wired / set up right.
2. is the tcs still inplace?
if u are running factory plenum etc then probly yes
(tcs is nobby looking thing that comes of pipe crossing over head and sits into the neo cover)
3. airbag light flashing cuz seat/dash removed at some stage
(either to fit pigyback as under passenger seat is common place or dash removed / replaced)
4. centre guages - nfi ?
not sure if there is a fuse for these or not but would look in drivers kick panel if there is
else the guage panel is pretty easy to remove so open her up and check wiring
else get someone who knows shiz to take a look and if cant figure it out ...
... good excuse to buy some new guages :laugh:
i'm no mecanic/auto elec guy but i hope this helps,
otherwise go see someone who specialises in 34's and they should know the score.
john.
https://www.sau.com.au/forums/topic/157776-r34-questions/#findComment-2936289
Well that may explain the tcs because the neo cover has been removed.,id say because of the intercooler piping. So than maybe tcs has been removed all together. Im getting a guy to look at the guages today he reckons its no big drama as heaps of shit has been played around with. thanks for the replies
https://www.sau.com.au/forums/topic/157776-r34-questions/#findComment-2937207
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
