Reason for selling is that I'm only using the car once a week and don't really need it anymore. Rego until November 2007.
Car is completely stock and has never been modified, it would be extremely hard to find a 32 that has never been touched. There is zero police attention so you don't have to worry about getting pulled over all the time or getting defected. If you are looking for something to modify from scratch this is perfect.
In great condition. Has already had all drive belts (incl. cam belt) replaced with a new high flow fuel pump installed recently. Never had any major issues.
Has a 2 way pager alarm with immobiliser and keyless entry. The alarm also has a built in turbo timer.
Manual
Exeddy Heavy Duty Clutch (less than 10,000km's old)
New High flow fuel pump (less than 5,000km's old)
Electric sunroof
15% tint
16" Sparco rims
Type M Bodykit
First Australian Owner
115,000 km
Oil and oil filter religiously changed every 5,000km's
Price: $12500 ono
In HPI:
Contact:
Amanda 0413120586 or email [email protected] or even just PM me
https://www.sau.com.au/forums/topic/157934-sold/
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
