Hey guys, I have the following parts for sale. Most parts were from my previous rides and no longer needed.
ITEM 1 Front cashew Coilovers to suit S13/180sx.
Description
-Came from a 180sx that was a straight import from Japan. KMs on coilovers unknown but are stiff and perfect for hill runs etc.
-From the pics you can see that they are camber and height adjustable.
-Slight knock on the LHS coilover, unsure the reason behind it. Possibly ball joints?
-Spring rate (approx) 8K
Price $200 ono
ITEM 2 Rear JIC Coilovers to suit S13/180sx/R32/C33/A31.
Description
-Came from the same 180sx that was a straight import from Japan. KMs on coilovers unknown but are stiff and perfect for hill runs etc.
-Better condition than fronts
-From the pics you can see that they are height adjustable.
-Spring rate 6k
Price $300 ono (Willing to do a deal if sold as a set and might even throw in a set of TANABE C spanners )
COMBO PRICE for the set of coilovers! $450
ITEM 3 Various stock rear bars (S13 burgundy, R32 silver 4 Door, R32 Black 2 dr coupe) and a stock Sr20 180sx front bar
Description
1) S13 burgundy rear bar - GC $50 ono
2) R32 4 DR silver rear bar - GC $50 ono
3) R32 2 DR black rear bar - GC $50
4) 180sx front bar (navy blue) - slight tear on the bottom $30 ono
ITEM 4 Stock R32 Suspension, great for clearing defects.
Description
-NB only good for clearing defects came off an R32 that has done 100,000kms +
price $100ono
CONTACT me via PM or sms 0434345424 for faster reply
Cheers andy
PICS UP ASAP
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
