hey Guys finally got the net back so i can enjoy SAU again
im after a new turbo to get my rb25 upto a nice usable power of about 240-260 rwkw
but also want response similar to stock.
ive been told a t3t4 will do this and still give me the reponse i want.
i know i will need to upgrade the injectors and fuel pump and ecu but the decision of
what turbo is my main concern ATM.
does anyone agree or disagree on this turbo
any thoughts would be greatly appreciated
Cheers,
https://www.sau.com.au/forums/topic/158517-t3-t4-garrett/
240kw maybe, but 260kws with cams,yes.Even at 240kws your really pushing the hi-flow turbo to anything from 16lbs to 19lbs which is alot of boost in a stock RB25.Watch the flaming now.
https://www.sau.com.au/forums/topic/158517-t3-t4-garrett/#findComment-2942839
GCG/Slide hi-flow... depending on your budget depends which of them you buy :)
I would go with what works on an RB25 rather than some hybrid t3/4 that potentially could be a lot worse then the two choices above.
T3/4's can be hit a hit-n-miss affair at times
https://www.sau.com.au/forums/topic/158517-t3-t4-garrett/#findComment-2943483
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
