hey guys, my mate asked me to put a pipe straight down the middle off his cat so its one pipe, just looks like there is a cat there.
I have a the cat and some 3" Pipe but it isnt sliding down the whole, how would i open the cat converter, put the pipe down the middle and put it back together.
I Have a every type off tool needed to do the job, just dont know how to wink.gif
Thanks
https://www.sau.com.au/forums/topic/158824-cat-converter/
Not offering help, just going to mention..
Even if that cat *looks* like its there, you can smell that there isnt. The cops or defect stantions or road side people have machines that can test that your cat isnt working (like same as bashing out the honeycomb stuff) and you *will* be slapped with a $10,000 fine. Not kidding.
https://www.sau.com.au/forums/topic/158824-cat-converter/#findComment-2948929
has anybody ever actually heard of anyone getting booked for it....?
also the $10,000 fine im pretty sure is only to a buissness if they do it for you, im pretty sure the fine they can thwack you with is less than $1000, and i doubt it would be onj the spot, it would be a proper emmisions check at EPA, at a later date....
you need a smaller pipe, or you need to grind the inside of the cat out by how thick the 3" pipe is (as the cat is 3" internal diameter, as is the pipe) you should be able to easily grind the couple mm out of the cat, but it will take some time. Thats what i did for mine, but i wouldn't recommend it, as while yeah it does make some power difference, it also makes RB's sound raspy and a bit bomby, im getting a highflow just to make it sound better, and getting a test pipe made for track/strip
https://www.sau.com.au/forums/topic/158824-cat-converter/#findComment-2949629
Go easy on our little planet please =)
I'm pretty sure i read somewhere that its almost worse for the planet (i.e. ozone layer) having a cat (with unleaded) as it produces random fumes (no2/sulphur?) but they have them to reduce smog etc caused by carbon monoxide, so in city's etc it reduces smog, but in the long run it kills the ozone.
don't know how true this is, google it...
but yeah, definitely go a highflow, just for the sound, you drive an RB - you dont want a 4 banger tinny rasp :laugh:
https://www.sau.com.au/forums/topic/158824-cat-converter/#findComment-2952953
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
