Hey all. I just thought i might bore you all with what i did tonite. Needed to remove my engine and gear box from my 1982 subaru to replace clutch and gear box. I started the task after tea around 7pm and managed to have the gear box and motor out in only 4hrs.
Well thats what i been doing. I know some of you will be like " thats slow as man" but i think its good. Ah well just thought i would share something.
Yeah its easier to take out gearbox with the engine than to f around with separating them in the car. Plus i am changing the gear box for another one that i had sitting around cos the current one is a bit f'ed. Yeah i did the whole thing myself and with a few beers lol. yeah had to remove front cv joints, tail shaft. I have removed the engine a few times in my paddock bomb so i had bit experience on this type of vehicle. would make life easier if i had a hoist. just used car stands and an engine crane. bit slower but does the job.
from engine running to gtr box out in 1 hour by myself, thats with no hoist and only axle stands and a jack to assist :P
gtr engine running and out in around 4 hours by myself as well
done box around 20 times now and engine about 10-12 times i think so gets easier the more u do it lol :laugh:
i know what bolt sizes are on every damn part of the engine and box, its pretty disturbing :)
lol nice work guys. yeah i dont think i would be strong enough to try and take gear box out from under and put it back in. hard to manipulate it in tight spaces. yeah i knew what alot of sizes where on my car. mostly 10,12,14,17.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
