The radiators in most autos also act as coolers for the transmission fluid.
You could probably get away with using a manual radiator in an auto if you hooked up an external tranny cooler....
but in a nutshell, the answer is no, you can't just whack a manual radiator on an auto
https://www.sau.com.au/forums/topic/158955-radiator/#findComment-2950609
