Selling these Work VS-SD wheels fellas. Bought them for my car but they were the wrong offset and fouled on the struts. The guy i bought them off has taken them back to his shop to try and sell them for me but hasnt had any luck as yet, so i thought i would see if anyone here was interested.
18x8.5 and 9.5 +45 offset all round.
More photos at:
http://www.rampant.net.au/shop/product_inf...products_id=192
On there the price is $1250 which is what i paid but im willing to let them go for less now, as i could do with the money.
The rims are currently located in Melbourne. Either contact myself or Aaron at Rampant.
Cheers,
Matt
[email protected]
https://www.sau.com.au/forums/topic/159330-wheels-18-work-vs-sd/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
