My cars currentlly sitting on lower'd springs with std shock obsorbers, the fronts are more low than the rear.being standard shocks,i have plans to get a set of coilover's when i come across a cheap reliable decent bargin. though not equiped with enough money, it wont be anytime soon.
on the other hand,I do have rear pairs of hks hipermax and was thinking about doing that for the meantime . Before i go ahead on installing them, just would like feedback on the downside of things.
bare in mind, its still on stock shocks with too low springs and doesnt handle as great atm so no biggie about handling issues .
Thanks
https://www.sau.com.au/forums/topic/159684-suspension/
understandable without a doubt.
but say for instance, if handling was poor and so are you.
ahaha would you?
Ok i must confess, "One Point" for me aswell is to have matched f/r suspension sort of commonsense.
Its not mine, Mine's full equipped but not full balanced with hks.nismo and cusco handling gear.
Its actually for the miss. Im trying to take shortcuts and just needed some "Wont handle like a race car, but better off a dori than a fullysick bounce machine" comments to make me feel less guilty treating a line like so.
Edited by CircleLights
https://www.sau.com.au/forums/topic/159684-suspension/#findComment-2965644
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
