As stated in title, im in need of a good condition timing belt tensioner pulley for S1 RB25DET. To buy one new, I have to pay approx $250 for a whole kit that i dont need as i already have a seal kit and timing belt.
https://www.sau.com.au/forums/topic/160252-tensioner-pulley/
try CBC bearings in NSW - you should be able to buy one individually or if no luck try these guys in Brisi - Bearing Traders Pty Ltd, they should be able to overnight it (07) 3808 2766. I used to get bits for my R32 from them, no probs. Even sourced a full timing belt kit and tensioner bearings + hydraulic tensioner for my '02 Magna and it cost me under $300 all up to get the bits sent to Canberra. should be under a $100 for the bearing for your Skyline.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
