  • Replies 133
Car is found now...
Has the issue been resolved yet in full Amy?
I went to see the owner when he got back from holidays last week. He said that no one tried calling him from his work and that they new where the car was being "stored". He had a look over the car and wasnt no impressed at the state it come back in. So he is getting all that fixed and sorting out the problems with it. The police are now involved and QLD transport, so hopefully it will sort it out.
:laugh: you gave it back to him ;) your a very trusting person :huh:
were u down there at around 7ish this morning cause i sware i saw ur car there?
TOYRB - pete had my car yesterday and it was parked at this work in moss street. so that why u saw it there it whats where it was
  • 3 weeks later...
