Hey guys
just wondering from a few of you with a bit of experience with drag racing in skylines, what would 50rwkw be worth in an r32 gtst??
I had a r32 a few yrs back which made 125rwkw (i dont care how low you think this figure is) and ran a 14.1 with a slightly slipping clutch.
Ive just had my car tuned and was told it made approx 175rwkw on the same dyno. Now the dyno is known to read up to in one case 40rwkw low, so i cant trust reading other ppls power figures to time run. With a decent run and the fact i have a very good clutch now rather than when i had a stocko on the original car what time do you think it would run realistically?
Thanks for your help.....Brett
https://www.sau.com.au/forums/topic/160577-whats-50rwkw-worth-down-the-strip/
to get a 14.1 with 125 kw is pretty impressive, maybe too empressive. did you get it dyno'd at the same place? i have 169 rwkw and with street tyres i have a 13.7 and i have been told that is good. 14.1 is a good time for a skyline, so with the right driving you probably get low 13's
I think one of the guys in a R32 GTST(RB25turbo) with around 180-190rwkw did a 13.6 pass.
well there is only one way to find out go down to the strip and see what it can do,
you can never trust dyno figures its a tool for tuning :(
You need to mention trap speeds. ET varys on power deliver and traction.
For example, I ran 13.3 with 215rwkw. Sounds about normal depending on what type of car and weight. But I did it at 114mph. So initially you could think that that was about right maybe a bit slow. Then when you mention the MPH you can see that there is power there but it hasn't been used efficiently.
to add further i ran a 13.4 with a trap speed of 103.5mph, the 10mph difference but only 0.1 sec slower. his car is more powerful showing greater speed but mine was a tidier run, more effective use of power. could be slipping clutch, wheel spin, poor launch, slow gear change, missed gear, bad tune.
Chris Davey: Is that 215rwkw in a Corona or R32 R33 GTS?..
Bretto:
When you do your run as Nismo_God has said; 60ft, Trap Speed & ET are all important factors to consider when judging your power.
have fun! >_<
thanks for the reply's ppl.
firstly yes it was at the same shop.
gt shortie i agree, thats why i asked, not sure if i wanna run it for fear of breaking something :ermm:
it was just under 100mph, but it was yrs ago, but i remember that. like i said the dyno is known for reading very low power figures. thats why im not worried about the 125rwkw (on that note, he had a stock standard r32 gtst on the dyno and it made 80rwkw, that should give u an idea of how low the dyno reads). after reading the rb25 turbo upgrade post on here and seeing some power figures some ppl are making with dyno graphs it makes me laugh.
Edited by bretto
I can't see you breaking much with 175rwkw. Take it down and let us know how you go.
To add to the thread. How much difference do people think 50rwkw will make at higher power levels?
GTShortie I think got a 12.7 or 12.6 last sunday and I got a 12.4. I think he has about 50rwkw less than me but probably a lighter car. Mine is 1580 with me and a full tank.
The lower the initial power (ie 125rwkw) the more difference the extra 50rwkw will make.
ie; The improvement in time from 125-175rwkw (maybe 0.5-0.7sec) than you will if you go from say 700-750kw (maybe 0.1 or 0.2sec).
  • 1 month later...
As someone mentioned you cant say 50rwkw equals x amount of tenths of the time as it depends on the initial power the 50rwkw was added to.
A 50kw increase on a 500kw car is a power gain of 10%. Whereas in your case the 50kw going from 125 to 175kw is a 40% power gain.
And you cant compare to other peoples results as you mention the dyno you went on is a little out of whack.
Which leaves only one way to find out.....
burnsie - as was stated the mph will be a true indication to power - your 13.9 was a very clean run, everything worked well.
my car just with the cat back did a 14.5 @ 95 with a 1.9 so around the 140-150rwkw
Chris - that 114mph is good for mid to high 12's!!!
  • 1 month later...
found this thread and have some more to add...
i ran a 13.426 with 1.970 60ft at 103.5mph with 169rwkw
now i rana 13.081 with 1.911 60 at 104.25 with say around 206(boost was higher then previously dyno'd)
so with an extra 35-40kw i made up 0.35 of a second....and not even 1 mph faster....
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
