200sx S14 Bilstein, Whiteline, Eibach & Noltec Suspension
Contact Details
Superior Suspension
4 Lincoln St Minto NSW 2566
(02) 9603 0100
I have just finished the engineering for Jamex on the 200SX S14 Bilstein, Eibach, Noltec and Whiteline Suspension kits. These have been extensively road and track tested over the last 4 months in three S15’s. Similar to what I did for R32/33/34’s, they will be offered on a Group Buy from Jamex for 15% to 20% less than the recommended retail prices, plus freight will be free for all orders over $500, plus there will be an additional discount of 5% for orders over $1,000.
The Group Buy kit was engineered (by me) to give a sporty, but not harsh ride, for the street and at the same time suite the sort of things that S14 owners use their cars for (road, drag and circuit). It’s a great all round kit judging by the comments back from the people that have tried it.
Due to the strut based front end there will be a basic kit with Whiteline coil springs. Plus a full height adjustable coil over kit utilising Eibach (the best) coil springs with Noltec adjustable strut tops as an option. Extensive engineering has been carried out on a full replacement coil over front strut which features a unique Bilstein shock absorber. Plus it allows greater scope for camber adjustment combined with the use of wide wheels and tyres.
Front Bilstein inserts and rear shocks
Front fabricated strut with the Bilstein insert
Rear Bilstein shock with Whiteline spring
Picture of Bilstein/Eibach rear coil over spring/shock unit
Picture of the Noltec adjustable strut top
Rear Camber Kit
Front Caster Kit
In all cases the Bilstein damper valving has been selected (by me) to suite the spring and stabiliser bar rates used. I have spent some time engineering in an additional 20 mm (23 mm at the wheel) front suspension travel to avoid one of the major limitations of the packaging in an S14. This means I could use a lower spring rate for better handling and ride and, at the same time avoid the bottoming out issues that frequent lowered S14's The Bisltein front struts incorporate an internal bump stop which has been rated and sized to suite the rest of the kit. For better control of dynamic camber and caster, the Bilstein front inserts feature the inverted layout which results in far stronger resistence to the bending forces that struts have to endure.
The rear Bilsteins are of course full shock replacements and the Whiteline Bump Stop & Dust Cover kit has suggested trimming heights as follows;
There is a full set of suggested alignment settings (including ride heights) for both road and track use, which are designed to optimise the handling and avoid excessive tyre wear.
Table of alignment settings
Recommended Road Settings
Front
Caster = 7 degrees positive (slightly more on the LHS to counter the drift to the gutter)
Camber = 1.25 to 1.5 degrees negative
Toe = Zero
Rear
Camber = 0.75 to 1.25 degrees negative
Toe = In 2 mm each side
Recommended Circuit (grip) Settings
Front
Caster = 8 to 9 degrees positive
Camber = 2.5 to 4.0 degrees negative
Toe = Zero
Rear
Camber = 1.25 to 2.0 degrees negative
Toe = Zero
Recommended Drift Settings
Front
Toe = Zero to 1 mm toe out each side
Rear
Camber = 0.75 to 1.0 degrees negative
Toe = Out 2 mm each side
Recommended Drag Settings
Front
Toe = Zero
Rear
Camber = 0.25 positive to zero degrees (never negative)
Toe = Zero
Price Lists
The Road Kit is designed for daily sporty driving and is suitable for occasional circuit, drag and drift work. Although an upgrade to adjustable stabiliser bars would be recommended for those willing to tune the handling for their personal preferences.
The price lists reflect a saving for SAU Group Buyers of $678 (around 25%) over normal retail prices.
The Road & Track Kit is suitable for road driving, to and from the track and other weekend work. Several of the guys during the testing have commented that they could easily live with the Competition Kit as a daily driver. The stabiliser bars are, of course, adjustable, plus the springs and damper rates are not in any way excessive. The recommended alignment settings are a bt extreme for daily driving and would result in excessive tyre wear if large numbers of kilometres are driven. The Road & Track Kit is priced the same for Drag, Circuit (grip) and Drift users. The spring, shock and stabiliser bar rates being the difference. So please specify your usage patterns when ordering.
The price lists reflect a saving for SAU Group Buyers of $1,215 (around 25%) over normal retail prices.
Availability
Springs are usually in stock at Whiteline and Eibach
Bilstein takes 1-2 working days to fit the inserts
Bushes are usually in stock at Whiteline
Stabiliser bars take 4-5 working days to make as Whiteline do not keep stock
Delivery is via Toll priority and usually takes 1-2 working days to anywhere in Australia.
Recommended Fitting Workshops
Heasmans Sydenham NSW
East Coast Suspension Kirrawee NSW
St George Steering Punchbowl NSW
Exceller Steering Bankstown NSW
Centeline Thomastown Vic
Traction Tyre & Suspension Rowville Vic
Manta Racing Services SA
Discount Tyres Service Belconnen Act
Motsons Qld
Wilkinson Suspension WA
As per the Skyines Group Buy, you can choose individual parts or groups of parts, just keep in mind the free freight for orders over $500 and the extra 5% discount for orders over $1,000.
Any questions? Send me a PM or post it here.
:( cheers ;)
PS; for S13 (CA & SR) owners, their kits are currently being engineered and will be released shortly
Sorry all, I have been out of action for 3 days, somebody gave me a nice little virus. So the PM inbox filled up, but it has been cleared now. So if you could n’t get a message though over the last couple of days please try again.
For those that did get a PM in before the overflow, please be patient I will get to them all sometime today (or tonight).
:laugh: Cheers :rant:
I am off to Bathurst tomorrow for the 12 Hour race, the race team is running (not a Skyline) and I have to do my Team Manager thing. I will be back on Tuesday, so please excuse the slow responses to posts and PM's.
:pirate: cheers :ph34r:
  • 1 month later...
Hi guys, my inbox is filling up faster than I can respond to the PM’s. I usually get 30 to 40 PM’s a day. With the current delay in delivery, that has increased to 40 to 50 per day and I just can’t keep up with that sort of volume. Particularly as some of the more technical PM’s take 10 to 15 minutes each to reply to and my available time has decreased dramatically for reasons which will become obvious shortly.
I feel that I need to “broadcast” a Group Buy update until I can clear the backlog of PM’s. Here is the current situation;
1. A little back ground first. As you may be aware Redranger and Whiteline merged a couple of months ago. The first step was a merger of Sales, Marketing and Distribution functions and Whiteline’s Minto premises were simply not large enough to accommodate this. So the premises adjacent to Redranger at Somersby were acquired and that was utilised for the larger, merged entity. Some people have taken this as a sign that Redranger “took over” Whiteline, when that is in fact not the case, it is a true merger.
The Whiteline manufacturing premises at Minto remain. More news on that shortly.
2. How this affects the Group Buys. Many of the products that I specified for the Group Buy Kits are unique, it is what makes the kits “work” better than any other Skyline suspension update. This uniqueness has been possible because of my knowledge of the systems within Whiteline (plus Bilstein, of course). The Redranger merger has disrupted that system and the “unique” (to the Group Buy) parts have not been flowing through as they had previously.
3. The good news. I have been working 14 hours a day, every day, for the last week, including yesterday (Saturday) helping to clear that backlog of orders. As a result, all of the Group Buy orders should be delivered this week. At this point I can’t tell you what day your individual order will be delivered. But as they flow through the system I will inform you of the con note numbers as soon as they are issued (the normal system).
In conclusion, I know you probably don’t care about the reasons, you just want your stuff and that is totally understandable. But I felt I had to give some background and let you know that I am working on clearing the backlog (personally as it happens) so that we can return to our previous prompt responses. Please hang off on the PM’s, I promise you that I haven’t skipped off to Brazil with your money. That your stuff will be delivered very shortly.
:) Cheers :(
  • 1 month later...
Is everything in stock ready to be sent for either kit?
Yep, but they are selling everyday, so that may not be the case every day.
:D cheers :D
  • 1 month later...
G'day,
I've tried to PM but your inbox is full and I haven't been able to get through for days…. Can I order the 'Road kit' for my S14a with the adjustable sway bars. this is my daily driver (approx 230-250rwkw) currently it feels nervous and unstable and not at all a joy to drive – I'm always fighting the car with every bump, divot and undulation in the road.
just a few questions... what spring rates do you recommend? – street use only (I want the car to feel fairly firm (sporty as you put it), just don't want my teeth to rattle every time the car finds a pothole..)
also just to confirm that both the front and the rear are height adjustable.
the other question is regarding the fabricated front strut that houses the insert - is that made by whiteline or someone else and will this affect my insurance if ever the tragic time comes that I need to make a claim.
Much appreciated :nyaanyaa:
G'day,
Much appreciated >_<
Try another PM, in couple of days please, as per above.
Regarding the strut legs, they are made by Bilstein in Australia. Since the front struts are "shock absorbers" they are "allowed" to be replaced. Just the same as the rear shock is a complete unit.
:D cheers :)
G'day,
Still no joy - inbox is still full...lol. just want to put in an order, know you must be busy. I'd like to order the Road kit with the upgrade to the adjustable sway bars for an S14a ('97). what spring rates would you recommend? this is my daily driver - has approx 230-250rwkw. car is on 18's, no idea what weight each rim is but i understand that this is a factor. ATM it feels like a sketchy, soggy, unpredictable mess, which is the complete opposite of what you want your car to feel like.
so how do i go about ordering the Kit from you??
can you please confirm quote $2190.70 (+ $62 difference in upgrade to adjustable sway bars)
total - $2252.70
can you please advise of bank details, also i know you must get asked this question daily but how long do you think it'll take with the back log of orders? delivery is still free for this kit, yeah? can you please PM with confirmation
Many Thanks Again :thumbsup:
Edited by Apex Trudger
  • 1 month later...
Above - YES
Hi All
Matt here
To Anyone who could not get through, I am now answering PMs and all questions for Gary the best I can. With the new business extremely busy, we have been flat out, however gary is off on Holidays to the USA next week for 5 weeks. This does not mean that sales will hault, as I will personally be looking after all sales and enquiries from this point on. For anyone with more technical questions, there are some I can assist with, but any that I can not will be forwarded to Gary.
So please, PM me (I will check the GB threads when possible, but PM is best - I will supply an email address and a phone number for me)
Cheers
Matt
  • 1 month later...
hey guys -- im not sure if this is gary or matt, but i NEED to place an order for the following items:
(2) S14 Front bilstein insert shocks
(4) S14 Rear shocks
(2) R33 GTR rear shocks
please email me at [email protected] so i can arrange payment and shipping, i hope this can get through to you!
  • 11 months later...
Guest
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
