Cefiro crossmember
squizz is correct. but you can also use the cefiro x member. both pretty much the same.
bigbignacha, the rb30 motor is to tall for the hood to close on a 240sx, thus meaning you'll need a custom hood with a ugly hump in the middle so it can close.
u can allso elongate the engine mounts as far as they can go the ones that bolt 2 the block custom inlet mainifold twin cam head and the rb30 should fit .The r32 and cefiro crossmembers r the same and yes they fit straight in to a s13 i have done enough rb conversion 15 in fact so i know how do them .Oh by the way the rb30 block is 1 inch taller than a rb20 or 25
hey,
i am doing the conversion, and just got a few quick questions.
- what radiator did you use?
- when you elongate the mounts do you mean lower them or get them custom made?
- what gearbox mount and exmember did you use for the r33 5 speed.
i am having problems with bonnet shutting, and i am using r32 xmemba and r32 engine mounts.
thanks for your time
depends on what you are after the only reason i would use the cefiro crossmember is if you want to keep the 4 stud slivia brakes but with an rb30 you will need something alot more serrious than standard slivia brakes
as for the crossmember try New Zealand there was a lot of wreaks last time i was there if you have problems finding one contact me and i will see what i can find
[email protected]
in any case it looks like a great project keep us in touch to see if it works
Guest bigbignacha
my project is an s13 240sx in the states. i have converted the hatch to a pickup bed just to be a little i know that it sounds ugly but it is starin to look good. As far as the motor i am just starting, i have the rb25det cylinder head and i am going to order an rb30 from a shop in adelaidef for 1500 plus 700 shipping to the east coast in the states. just like everyone else in the states i dont know much about the rb30 except for the fact that it is an extremely rare conversion here but now the shape of my car is rare so i guess it will work. also i was going to do an r33 headlight conversion but i think i want to go with an r32 conversion so if anyone wants r33 headlights in exchange for r32 pm me :P
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
