hey all,
It's time to sell the Rex i don't drive it enough and i need to start fixing the Skyline...
01 MY02 WRX hatch-back
Blue 120,000kms (mostly highway previous owner was in army and moved between states often)
Major service done at 112,500
Mostly stock only has MRT rear muffler and mrt enhanced stickers, never boosted, 17" mags(scratched) new rear tyres will be fitted before sale
very clean car interior and exterior always garaged
Located in CQ
SAU price $23,800
Note: I can't post pics so PM me and i'll email them to you
Edited by axe s
https://www.sau.com.au/forums/topic/161067-01-wrx-hatch/
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
