Hi All,
I have for sale a brand new Garrett T51R (GT4502R) 1.22 Ex A/R 75mm comp roller bearing turbocharger that I was to use on my new setup but have once again changed my mind and opted for a new/different setup
This turbo is rated at around 1000hp and is still in the GARRETT box in which I purchased it in
These retail for $2830 + gst
I looking for for $2200ono
-Also have a BRAND NEW 600-300-100 intercooler with polished end tanks up for grabs and im asking for $200ono
Vic Buyers preferred also
So if your looking to save a few $$$ on a brand new turbo/cooler for a killer setup then this is for you
If you require any more information/pics etc dont hesitate to PM
Cheers, shannon 0434 890 939 or pm
Edited by TTWPN
https://www.sau.com.au/forums/topic/161456-fs-garrett-t51r-1000hp-turbo/
hay mate i rang u on the weekend its dean can u show me some pics thanks. if all goes good i grab it this week
Hey dean,
Mate i can get you pics late 2nite when i get home from work. Plz pm email address
Check on the garrett website if you cant wait till then. This turbo is brand new and has only been taken out of the garrett box once when i had a look at it when it arrived.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
