WILL SWAP FOR OTHER PARTS
Will post, through Auspost or Busfrieght. The post price listed is to ACT/NSW/VIC, other states will probably cost a tiny bit more.
R31 Gear
*** Suspension/Steering ***
P/S Pump - $20 + post
P/S Rack - $50 + post
Struts Combo - Shocks/Springs - $20 each
Front Brakes Calipers - $20 each
Rear Brakes Calipers - $20 each
Sway Bars - $20
Control Arms - $20 each + post
Radius Rods - $30 + $10 post
Steering Columns - $50 + post
Panhard rods - $20 + post
*** Engine/Exhaust Gear ***
RB30e Pacemaker Extractors - $150ono
RB30e Head - FREE, as i've just got bored and left it outside
SC14 Supercharger kit (unknown condition)- $400
RB30e Engine Block+Head (runs really good ask Bluprint) - $100
RB30e Engines, please ask if anybits are wanted - $400
RB30e Air Flow Meter - $50 - I don't think i've got many left
Standard Exhaust System minus cat- $50
Standard Cat - $30 + post
Assorted A/C Gear - $20
Pintara Radiator - $40 - Oh yeh, some guy owes me money for this
Engine Mounts - $10 + post
Engine Cross Members - $30
RB30e wiring - $....
Turbo Exhaust Manifold - Not forsale
*** Drive Line Gear ***
S3 Auto Box - $100
Auto Tail shafts - $80
*** Exterior ***
S3 Centre Garnish - $20 + post
Sedan/wagon Doors (some maybe rusted) many colors, might have doorcards- $50
Fuel Tank - $20
Tow bar - $50
Windscreen Wipers - $10 each + post
Windscreen Motor - $10 + post
Windscreen Linkage - $20 + post
S1 Rear Tail Lights and Garnish - $50 + post
*** Interior ***
Interior bits - $5-$80
Interior Carpet bits - $10-$80 Gone
Standard Steering Wheels - $10 + post
Front Seats $20
Rear Seats - $20
Seat Belts - $10
Tape Decks/Head units - $Varying
*** VL Turbo Gear ***
VLturbo Dash - $100 + $25 post
VLturbo Power Steering Rack and res - on hold
VLturbo Struts with lovell springs - $250
VLturbo Swaybars - $50
VLturbo AirCon Pump thingy - $50
VLturbo Rear Tail lights - $80
VLturbo Chrome Tow Bar Tounge
VLturbo Water Res Bottle.$25
VLturbo Dash Badge - $125
VLturbo Diff(disc to disc LSD) - $1000 - SOLD YAY!!!
VL Rear Bumper - $50
*** R32 GTS-T Gear ***
R32 Hicas - $100 + post
*** S13 CA18DE gear ***
- CA18DET Manual Conversion, box, stick, rubber, crossmember, clutch plate, pressure plate, flywheel, master & slave cylinder, clutch pedal, brake pedal, tailshaft - $700
- Various Looms - $50
- Tail lights - $80
- slightly dented boot - $50
- slightly dented rear bumper - $40
Things sold out of the silvia.
- CA18DE, loom, ecu, afm, intake, exhaust manifold, engine pipe
- Front struts, knuckles, hubs, brakes, control arms, rotors
- Rear diff, axles, control arms, cradle
- Steering column
- Boot hinges
*** R33 Gear ***
- RB25DET Engine Crossmember - $200
- Top wishbones - $120 pair
- Steering Column with barrel and key - $100
- Some Dash control thing for Air/con - $80
Edited by StinkyPoo
How much HP will the RB30e AFM support?
How many you got left?
  • 1 month later...
Hi there,
What car are these parts from?
Are they Frnot Lower Control Arms?
Regards,
Sherwin
hmm, i forgot about this thread...
Top stuff is R31 gear,
Each section after that has what ever car they were from.
RB30e Extractors were sold ages ago.
  • 1 month later...
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
